Fueling bits - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: For Sale (https://www.306oc.co.uk/forum/forumdisplay.php?fid=26) +--- Forum: Parts (https://www.306oc.co.uk/forum/forumdisplay.php?fid=25) +--- Thread: Fueling bits (/showthread.php?tid=32041) |
Fueling bits - bashbarnard - 28-09-2015 10mm fuel filter housing that has primer built in with spare brand new filter. £15 9mm bosch gov mod. Needs reseal. £30 11mm bosch pump hasnt been ran yet but took apart to fix. Didnt re seal. Should be fine. £50 Loads of bosch ve spares. All prices are plus postage. Need rid. Need the money. RE: Fueling bits - Paul_13 - 28-09-2015 I'll have the 11mm pump when I get paid on Wednesday if that's cool? RE: Fueling bits - bashbarnard - 28-09-2015 Fine by me. Provisionaly sold. RE: Fueling bits - bashbarnard - 28-09-2015 9mm pump sold as well. RE: Fueling bits - Teddy - 28-09-2015 Has 11mm gone ? RE: Fueling bits - bashbarnard - 28-09-2015 Provisionaly sold to Paul pending payment. RE: Fueling bits - blinkyeatu - 29-09-2015 Ahhhhh bash what a savior I need the black lever bit and at least one of the little springs how much posted with asap posting RE: Fueling bits - bashbarnard - 30-09-2015 There are lots of little springs. Lol. Lever set i have springs i probably have as well. The return springs? RE: Fueling bits - blinkyeatu - 30-09-2015 these ones also if you have the lower right hand mounting bolt and nut (the one by the injectors) that would be pretty cool. Is the Bosch pump meant to be on the more advanced stud pattern on the bracket ? Cheers RE: Fueling bits - bashbarnard - 30-09-2015 Got the internals not sure about the bolt though. Ill look today. Say £10 posted? RE: Fueling bits - blinkyeatu - 30-09-2015 That's great cheers Pm me you details and I'll put the money in RE: Fueling bits - bashbarnard - 30-09-2015 These bits. And pmd RE: Fueling bits - rryan - 30-09-2015 do you have a ve advance piston, and a 'idle' spring (the spring inside the pump that fits between the leverset and cold/hot idle lever) cheers RE: Fueling bits - Paul_13 - 30-09-2015 Send me your payment details mate please RE: Fueling bits - maxlee - 09-11-2015 by any chance do you sill have the filter housing if so do you have a pic/ruff size |
