Gsxr T-B's + Cut Down 16V Xu Inlet - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: For Sale (https://www.306oc.co.uk/forum/forumdisplay.php?fid=26) +--- Forum: Parts (https://www.306oc.co.uk/forum/forumdisplay.php?fid=25) +--- Thread: Gsxr T-B's + Cut Down 16V Xu Inlet (/showthread.php?tid=31696) |
Gsxr T-B's + Cut Down 16V Xu Inlet - welshpug - 24-08-2015 Can't see me using these any time soon, so they must go! GSXR 750/1000 individual bodies already spaced to suit the 16v XU inlet manifold, I bought the inlet already done, its had tubes welded on to suit silicone joiners, I also have a lump of alloy which could be welded on and have ports added to bolt the bodies on properly as done by Satchell engineering. What you see is what you get, £200 posted. RE: Gsxr T-B's + Cut Down 16V Xu Inlet - Matt - 25-08-2015 I'm. So. Damn. Tempted. RE: Gsxr T-B's + Cut Down 16V Xu Inlet - welshpug - 25-08-2015 DOOO EEEET. RE: Gsxr T-B's + Cut Down 16V Xu Inlet - Matt - 25-08-2015 I should proberly get it on the road first. If, they are still for sale in like a month I'll definitely have them RE: Gsxr T-B's + Cut Down 16V Xu Inlet - RetroPug - 25-08-2015 I take it the next steps would be: Join inlet to TBs with silicone joiners or by welding on alloy with bolt holes or something for TBs Adapt throttle linkage? Fit TPS in place of bike TPS Plenum for ICV and MAP? Fit std. fuel rail and injectors Fit and get Std. ECU mapped by wayne Anything wrong/missed out? Thanks RE: Gsxr T-B's + Cut Down 16V Xu Inlet - welshpug - 25-08-2015 not too far off - no need to replace the bike tps. no need for a plenum or icv. you'd need trumpets, there's a few guys doing suitable ones, Satchell engineering probably best as they are known to perform, and also can have the filter backplate bolted to them, RE: Gsxr T-B's + Cut Down 16V Xu Inlet - RetroPug - 25-08-2015 I see, you can use the standard ECU and map out the ICV and use the bike TPS to provide readings? Then use standard loom and change plug to connect to bike TPS and leave redundant sensors unplugged? What aobut MAP? Oh yeah, forgot about trumpets and filter. RE: Gsxr T-B's + Cut Down 16V Xu Inlet - welshpug - 25-08-2015 no idea about all that, you meed to ask Wayne Schofield or get a dta or omex that nearly anyone can map. RE: Gsxr T-B's + Cut Down 16V Xu Inlet - RetroPug - 25-08-2015 Okay, thanks for the info. |
