Hello All.
My Hazard Lights are not working but indicators ok on my dturbo.
No ideas on what it could be.
Please help!
Thanks
Sam
If the indicators are working, I wouldn't have thought it would be the relay, don't suppose you've got a spare hazard switch you could try?
Hiya mate,
A few months ago the indicator stalk developed a fault, left indicator would not work, after replacing the stalk, hazzards dont work.
Tried a repalcement switch from another 306dt but no joy.
Ive a got spare 306 which i use as a doner car for bits that i need on this car.
Due you have any ideas on what relay it could be?
Thanks
Sam
Doubt its the relay. All the indicator wiring passes through the hazard switch so id check the plug to that.
AHHHHH! Starting to looose it with these hazard lights!!
Someone please help!!
looks like its the alarm wiring. taking ages to fix, failed MOT cos of this.
You've had quite a few problems with the car haven't you. They make terrific banger racers.
was a 30amp fuse missing.
Glad u sorted it mate
Works spot on! also this fixed non working rad fan!
