24-06-2013, 06:42 PM
Peugeot 306 1.4
ADVISARY PLEASE DO NOT USE BRICKS AS A STAND.(I DID IN THIS INSTANCE AS I HAD NOT STANDS AT THE TIME BUT FULLY SUPPORTED ELSE WERE)PLEASE USE THE CORRECT STANDS FOR THE JOB.
DRIVE SHAFT.REMOVE/REFIT
Hi guys thought id do a little write up on how to change the drive shaft this is virtually the same both sides. I know its like sucking eggs for most of you but might be helpful for some one
Here we go
1) Firstly ensure you are on a level ground and have all your tools ready and you intend to drain the gearbox oil(why put a new shaft in and use old oil). I’m not going to list every tool you need we all know what size sockets are try em until you find the right one.
2) The next thing you want to do is chock your rear wheels. Now if you are doing this on your own I would chock the front wheels also just for now.
3) The best way to undo the retaining nut for the driveshaft on your own is to leave the car on the ground remove centre cap or wheel trim get your (30mm) socket with your breaker bar or your piece of scaffolding and loosen off the retainer nut not all the way but enough to be loose.(if you have a buddy get him to put his foot on the break pedal whilst you slacken off the nut).[/URL]
4) Now that you’ve done that loosen off the wheel nuts and then jack up the car and support it on either jack stands or if you’re a pikey bricks..
5) Next undo the wheel nuts and remove the wheel(I put this under the car in case a stand fails or jack breaks) next thing to do is to get the ball joint off the wishbone there are three nuts behind the disk. They have a star key on the top and a (15mm)bolt underneath .undo the nuts and leave the bolts in.
6) Now we need to move under the car to the mounting bracket o/s (drivers side)(open the bonnet for more light) looking at the bracket you will see two nuts on the left side these are the retaining clips for the middle section of the shaft. these need to be undone practically to the end (try and keep the bolt on there). Now if you move your head to the right side you will or might be able to see the retaining clips theses need to be turned about a 180 degrease.
7)now popping back to the side of the car (make sure you have a pan to catch the remaining oil in gearbox YOU SHOULD DRAIN IT FIRST REALLY)Time to take off the retaining nut. remove ball joint bolts(these can be a bit tricky you may have to turn the steering to remove)once they are out place your hand on the bottom of the break disk and give the driveshaft a hit with a rubber hammer this will free the ball joint from the wishbone and the shaft from its housing.[URL=http://s1166.photobucket.com/user/jonnotheone/media/SAM_1133_zpsdf6eb66c.jpg.html]
8)going back under the car grasp the driveshaft near the gearbox and give it a tug it will come free. now it is free from the gear box you can come round the side of the car and slide it out the rest of the way. And there you go driveshaft is out.
To refit just work backwards from 8 to 1 cant go wrong.
If your doing n/s (passenger side)skip most of step 8.
)ADVISARY PLEASE NOTE IT IS NOT RCOMENDED TO USE BRICKS TO PROP UP YOUR CAR BUT IN THIS INSTANCE I DID I STACKED THEM 3 ACROSS BY 3 ACROSS CRISS CROSS FORMATION PLEASE USE EVERY CAUTION WHEN WORKING UNDER THE CAR)
Here we go
